jclars
I had to cut the firewall to allow the AOD tranny to clear, otherwise the engine top side cleared okay. So I positioned the tranny relative to the IRS and measured for motor mounts. I wanted to place them on the IFS subframe in the same spot as the Jag and because the T-bird also put them on the subframe. So I took the T-bird mounts and created elevated pedestals on a base that could be fine tuned for position later.
Once this was accomplished, it was time to take the cab off to work on the rear mount.
The fun was just starting...
