DozerII
It's nice to watch you work Dozer.
Keep on tinkering.
Thanks MM.
Keep on tinkering.
Been working on a bunch of little stuff most of the week.
Sooner or later it all has to get done... right?!?
its looking super great !
a few things I have learned about bags, coming from a guy who has had 10-12 bagged rides in more configurations than you can count:
fully compress the bag when you are aired out, otherwise you waste air filling that uncompressed volume. that doesnt sound like a big deal, but depending on your tank volume and compressor recovery time/duty cycle, it could be the difference between filling bags and leaving or filling them partway and waiting for recovery to fill the rest of the way before leaving. if you are over 100 psi lifting the front end to ride height (with a dressed truck: engine/sheetmetal), you have extra volume, 90psi should lock up a gm truck front end (lock up is a term that is used to describe the ball joint limiting upward movement, once you hit that point on the ball joint its "locked" and no amount of air will raise it any more).
I notice you have the bumpstop in there, you can take it out completely if you want, most double convoluted bags (the type you have) have internal bumpstops. if you are using the bumpstop to set the aired out height, you may have to adjust the lower cup up to get a full squish on the bag. but if not, youu can trim the bumpstop to the full squish position.
ride height on a double convoluted bag is right at half travel, any more and the spring rate gets stiff and bouncy, any less and the spring rate is too soft, foaming the shocks and bottoming out the bags on bumps. setting the truck for ride height at half travel takes some forethought, because half travel on a 2600lb bag like you have will only be about 5 inches from compressed (that is counting the geometry of the front end too, a 2600 lb bag only has about 6 inches of total stroke but with the geometry of the a arms you get about 10 inches of travel). fair warning: most first time airbag users want to ride higher than half travel, it just doesnt feel like enough lift. but really it is.
Your welder's workin' good. [cl
Nice fab work Dozer. Look's great. [P
Very nice looking beads Dozer!
nice welds! [cl[cl[cl
^^^^ X's 2 ^^^^
[P [P [P
