I got my rod on the road about a month ago. 1200 miles on it already. Overall it handles great, steers great, and goes through the curves great. Having put many miles on original model A fords, I expected some jolts when I hit bumps in the road and it handles them pretty good.
I would like to tinker with the suspension a little more to smooth it up some more. I have a medium rear spring from Speedway and a three leaf on a tubular straight axle in the front. I installed some light duty coil over shocks on the rear to help the rear spring out a little. The front shocks are gabriel and I just selected some that fit to put it bluntly. The front end seems really rigid. the shackles are at 45 deg front and rear sitting level.
Bumps seem hard in the front and softer in the back. I am thinking I have too much resistance with the front shocks. I can sit on the tail gate and the back of the car will ease down like you would expect it to. On the front, the spring seems stiff and it does not give much.
When driving, I cannot see the shock moving when hitting normal bumps in the road. I am a retired engineer, but I really cannot find any method to determine how to size shocks. I used Gabriel shocks as they were cheap. The hot rod shocks from speedway and summit must have gold plating or something because they cost a fortune. I don't mind spending a few bucks to make the ride better but I don't like guessing when spending at least $200 bucks for two shocks for the front.
My gut tells me the rear is ok but the front is to stiff and the spring, even though it has the shackles at 45 deg, just seems stiff. Thinking about taking the shocks off and driving it around to see if the wheels bounce more. That might tell me I need less shock than I have.
I have read several good articles that say most rods are not set up right. teams of engineers design standard automobile shock systems, but there must be a good logical approach I can use to avoid buying expensive shocks that do not help.
This forum has been very helpful for me during the entire project. I started from scratch back in September 2010 and got her done in 5.5 months doing everything myself. I knew spring overs were rough rides but they are so damn simple and cheap and do a good job.
Any suggestions are welcome. Its ok like it is, but I am sure the wife would not mind an improvement in the ride comfort level.
Thanks
Bob in Ga.
Thanks
Bob in Ga.
