I got the brake problem worked out, found a under dash assy on ebay for $115, had to do some trimming on it but I got it in the small space. Going to be a little tricky to fill but I'll manage. I braced it really good, pedal is where I want it and it's got a 7-1 ratio. Redid my steering arm, now you can get to the grease fitting. Got a call today saying my engine machine work is done. 427 BBC, .030 over, I set it up for boost, JE pistons, upgraded wrist pins, rings are JE for boost, H beam rods, steel crank. I had the block decked, ARP main studs and aligned bored. I'm going with 425 HP heads with a tunnel ram and 2 600 holleys for now. 657 lift hyd roller with all MSD ignition. 350 turbo is done, coan parts with a 3200 stall converter.I'm hoping to make some considerable progess in the next couple months.
