There's times I think I'm getting too old for this crap.![]()
My attempts to get the washer out through the spark plug hole were unsuccessful. In the high humidity and 90 degree heat I pulled the head after removing all the stuff attached to it.
I looked in the cylinder. No washer. I looked in all the cylinders. No washer. What is happening? I swear I saw it go in the manifold. Could it be the mushrooms the little woman served with supper? Too much Jim Beam? Time to get my eyes examined? Head examined? Maybe it dissolved?
Went to my favorite parts store and found out their warehouse no longer has head and intake gaskets for slant sixes. Luckily Rockauto has what I need.
Whole lot of sweat for nothing, but I had to be sure...
[cl[cl[clGot the head gasket from Rock Auto today. This is the box it came in. There was enough room in there to house an extended family of hamsters.
Before I put the head back on I took another look in the intake ports. In #2 port, tucked behind the valve guide, up against the valve pocket, was the missing lock washer. So I'm not crazy nor was I hallucinating. I did see the washer drop in there. I had rotated the head and thought that was enough to cause anything in there to fall out. Wrong! I really would have been upset if I put the head back on with the washer in there. Got unlucky first, then got lucky. Whew.
P.S. I switched from Jim Beam to Southern Comfort for my nightly nightcap.
