CR55
It's just a little surface rust!
Wow, that's gonna look great![dr...CR
Very nice car!! love the headers!!
If you dont mind me asking... what kind of setup do you have on the front of your car?
Im trying to build a 31 and I have no front end at all.!!
any help will be great to lead me the right way.
thanks matt
It's a '37 ford axle and spring assembly , I removed three or four leaves from the assembly . I used a cadillac fwd rack and pinion and removed the left tie rod from the rack and pinion . the right tie rod hooks to the steering arm then used a drag link to connect to the left steering arm with heim joints . It sounds like a lot but it is a very simple system that steers very well and is extremely "tight " hardly and play at all . I also used a speedway front disc brake kit with f 150 rotors and caprice calipers , that kept the 5x5.5 lug pattern all around .
