truck6jason
Active member
- Joined
- Aug 21, 2011
- Messages
- 44
128" is the current wheel base. Factory was 103" and I moved the rear axle back about 10" so that should be about 15" of stretch for the front, or somewhere around there.
If you inflate the rear bags all they way they open about half way, can't use them but made them open just for the hell of it. I wanted to be able to use them but I needed room behind the axle for fuel tank, air compressor, and suspension valves....oh wellstill wanna know how you get the back doors open????
I say you cut out the door in the shape of the tire with a couple inches clearance, and then weld that to the body, then you can open the door.
[P[P[P
Thought about it but it's right in the corner of the window and wouldn't be able to have a lower hinge.
