The Poly engines are an animal all their own. They have quite a few different versions depending on when they were built. The link BlueNorther provided is a good read and starting point, but some of the other statements were incorrect. Depending on what series Poly you are working with, from some to quite a few parts can interchange with a LA series engine. Also, not all of the Polys have the later bell housing bolt pattern, so matching transmissions isn't as easy as it sounds. I have had a Poly-powered '58 Belvedere for quite a few years now so I am pretty well schooled on the Plymouth variety. The Dodge not as much, but enough to be familiar. They can produce some respectable numbers with work, but be prepared for sticker shock as with any old engine. However, in stock form they are rock solid performers and capable of most anything you need to do. My Plymouth just turned 100k on the original engine and it is still going strong. Just did a 950 mile round trip in it last month at highway speeds plus and she never even stuttered. I am a believer...
