Snopro, I have a brand new old stock Mopar tierod end and tried it but the spindle steering arm hole is too big and the taper is wrong. Also my cross-steer rack and pinion has a short rod out the right side so I need about 18" yet to get over to the wheel. There are probably long tierod ends with the right stud, but the parts man would have to do some impressive digging and with my luck of the draw I wouldn't get that type of partsman.
Doc. while I was explaining that I could go two different ways with the threading, this morning, I got thinking there might not be enough meat left over on the draglink if I lathed in 11/16 internal threads. Sure enough, when I measured the shaft, I would have paper thickness of metal so that's out. I will have to put external, lefthand, 11/16", fine threads on the end and get one of those turnbuckle sleeves.
Today I tackled the back of the front springs. The old hangers came out, with a bit of coaxing, but the new ones are trying my patience.
