[pic one] is the long handled emergency brake that won't fit under the dash, and the shorter, older one with no mechanism.
[pic two] is the mounting bracket added and some of the notched semi-circle for the ratchet.
[pic three] is a return spring mounted to keep the dog engaged in the ratcheting teeth.
[pic four] is the whole new E-brake manufactured and mounted on a mock-up trial.
    4.1 MB
    3.2 MB
    2.5 MB
    4.1 MB
I put the freshly painted E-brake back on and started a couple of other projects. The first one is the gas pedal and linkage. [pic one] is the carburetors back on, so I can plan all of the new linkage.
The second thing I worked on was the speedometer cable. It was broken and the drive unit is at the back of the transmission and in front of the E-brake drum. [pic two]. It is also counter sunk about four inches and behind the E-brake mechanism. It is really, really hard to mount anything to. I made a five inch adapter and thought 'if I have to weld an inch onto the cable, why not weld six inches on there and call it good'.
    3.7 MB
    3.2 MB
I've always wondered about fuel distribution and atomization from those 3x2 to 4-bbl adapters. Curious how hard it will be to tune. Looks like you have progressive linkage for the outer carbs?
SnoPro, I always wanted to have the three deuce look so I got one of these units, as there weren't many intake manifolds for three carbs made for these motors. I did get to hold a three deuce intake in my hands at Pamona Swapmeet once, but the guy wouldn't sell it. The three deuce set up on my flathead looked a way more sophisticated, but it starved two cylinders with the progressive linkage. I think this set up will work better than that one did. I made the linkage for this set up. And those are three Strombergs.
Today was speedometer cable day. [pic one] is the long cable repaired. I brazed about 1 1/2" of new cable onto the end of the 1934 broken cable.
[pic two] is the five inch extension housing that I talked about yesterday. [pic three] is the cable for the short housing. Both ends of the cable are brazed.
[pic four] is the short housing screwed in place. The cable is inside it. Yesterday, I was grumbling about the horrible place this housing had to screw onto, well, I wasn't lying this time.
    3.5 MB
    2.8 MB
    2.7 MB
    3.2 MB
Creative engineering! I like that. You stepped up to the plate on that one. Good job!
But, it is a good thing I won't have to replace the cable extension, I'm afraid there wouldn't be a functioning speedometer.
Thank you Gene. Most people call that fiddling around, [not creative engineering], but there is more to the story. I probably will have to put a speed changing transmission in the system, and I can't fit in at the back of the big trans, so now I can hook it on out there in the open.
[Pic one and two] are the illusion of profitable progress. This is proof that my cordless drill can make that old speedo work with the long, welded up speedometer cable attached. The speedo probably hasn't registered any positive numbers for about 50 years.
You guys know that the cool hotroders have Stromberg carbs on their three deuce set-ups. Well, those are Stomberg EE's. The really, really cool hotroders have Stromberg WW's like mine.
    2.4 MB
    2.2 MB
Love those classic original gauges and speedometers, but by the time that kind of stuff gets to my place, its usually junk. The modern stuff is ugly, but often much less stressful to make work. The speedometer in my 49 is electronic, a small sending unit on the trans with a 2 wire plug, and a speedometer with no cable, just the plug in wire terminal.
When I built my 49, the primary goal was to get it to the street. The 49 was just outer sheet metal stripped of any extra original stuff, so the donor Dakota provided the instrument cluster. The original thought was that someday I would build an "old" dash with real gauges. Given my current state of ambition, that original thought may be another thing to add to the list that was wishful thinking.
I enjoy what I have built, but I live through what you guys build. Thank you for letting us participate.
Good point. I really like the idea of the 3-deuce setup for my roadster, but for ease of tuning I have a 4-barrel street avenger and dual plane edelbrock intake.
I cut my original gas pedal linkage apart and mounted it, [the bent horizontal rod in the picture]. While I was 'imagineering' what to do with the linkage from here, I spied the oil pressure gauge line delivery hole blocked off, [the brass fittings in the picture]. I unscrewed the block, hunted up some brass fittings, and screwed it all together. This looked like it had to be done before the floorboards were laid down. This way it was just a horrible job, instead of a near impossible job.
Anyhow, the gas pedal linkage as shown will not work, so I robbed my gas pedal stash and started over with a different set up.
    4.1 MB
As it turns out, I had to take two gas pedal mechanisms and cut and weld them together. The linkage pivot had to be moved up a couple of inches, to get the 'throw' of the pedal to match the travel needed for the carb throttle drive plate. [pic one] is the new linkage bolted in place. It seems to be a way over to the right hand side too much, but I had to miss the distributor, that's right in front of the firewall. There has been lots of fiddling around.
    3.8 MB
To keep with my fake authenticity, I am using the 1934 gas pedal to run the pivot mechanism. When I sat in the seat again and pretended to drive this beast, my foot was bent unnaturally at an idle and cruising speed, so I boosted the back end of the pedal up two inches. Then the ninety year old rubber hinge/bracket on the bottom of the pedal didn't pass the test so I made a steel hinge work in there instead.
[pic one] is the old pedal with a whittled down two by three block screwed the the hinge. the funny little ring thing is going to be pushed into the upper end of the pedal and it will slide on the pivot mechanism that I made yesterday.
    2.5 MB
Now I've finished off the gas pedal linkage, [pic one, outside the cab; and pic two, inside the cab]. That is until I tested everything, aggressively, and broke some ninety year old glue that holds on the rubber socket underneath the top of the pedal.
Then I cut out templates and made floorboards. [pic three].
    3.8 MB
    3.6 MB
    3.6 MB
Today was steering day. I've been racking my brains for a while on how to set this contraption up and have finally decided on this. [pic one] The funny looking lump in the steering shaft is a 'quickener' according to the race car guys. It gears the shaft up faster, ----- unless you put it in backwards, and then it's a speed reducer. This should give me almost power steering, 'Armstrong'. This is the second configuration only, but I think with a couple more tweaks, it will be golden.
    3.8 MB
