35binder
Nice
Great job you have done there! That truck looks great with the chop you did. Stance is perfect with the perportions of the truck. Most important was built with safety in mind. GOOD JOB!!!!!!!!!!!!!!
Curt
Thanks guys I sure did like doing the build and being my first one I sure did a lot of pondering LOL my wife says (chip you sure walk around looking at that thing a lot !) but as someone once said an hourof thinking will save you a day of redoing...
overflow tank
I found this can or as I will now call it ,my overflow tank a little bit large but what the heck it'll work if'n it don't ,,well thats what I got a grinder for :D. I think it will also help fill in that void I got there..what ya think ?
    186.8 KB
    187.3 KB
windshield wiper
next I needed to make a wiper control(so I can get tags)the idea is from my 29 AA. Taking a large bolt I drilled a 1/4 inch hole through it and mounted it through the existing hole in the cab. I then took a 1/4 rod bent it, threaded it and fit it through the bolt.Were on the other end I atached an old window crank (from the FIND:D)I took a cutoff wheel making a groove in it were I attached a square headed nut and WALA,I now have a functioning wiper control, still need a blade but kenworth makes just the right one!!
    141.9 KB
    133.8 KB
    140.4 KB
    127.8 KB
    111.6 KB
