And with that out of the way I can comfortably move to the rear of the vehicle to re-do the other area with which I am unhappy.
Wheelwells on old cars and truck were rarely – if ever – circular and whenever I see one that is, I usually suspect somebody who is stuck in the 70′s had their hand in there. The last thing I want on this is something that looks as if it were molded in. So looking from the side, the contours are just fine for me: rounded, but not so round as to look like it was form-fit around the tire.
But from the back, Oh My God – Becky will you look at that butt?!
Actually the problem is that it narrows too quickly. Using the original flare that served as a mount for the fender proved to be a mistake. Where the trunk abruptly cuts-in, so does the fender-mounting flare. I want it to flow back in a taper that is much more pleasing to the eye. Subsequently, the flare needs to be wider alongside the trunk and I’m going to need some sort of line to shoot to to keep both sides the same.
Enter the 7/16″ cold rolled round stock. It’s a little smaller than the stock bead around the opening and by bending it to shape I can use it to run both my new inner wheelwell and the outer flare.
Mirroring the front curvature to the rear worked for the profile the first time, so there’s no reason not to repeat that performance again. The only problem is that I tossed my plywood pattern when I “finished” this the first time (The pattern is visable about half-way down in
this post on my site). Never, Never, Throw anything away!
No bother. I’ll just bend it around the stock front opening and swap each one to the other side’s rear. I made two, symetrical pieces this way.
Then I removed a small section of the offending bead and slid the round stock inside.
Here's a look at the line from front to back.
I'm alternating back and forth, doing each step to both sides in an attempt to keep it all symmetrical and this is where I left off for the night. It's much more what I was looking for. I'm glad I cut back into it.
