4 link rod ends
Merc52
May 22, 2015
124
Wisconsin
What have you guys been using?
I have bungs 1-14 but I can't fint rod ends for the bung that is less then 3 inches. What I want to use in a rod end with bushings. Any help is appreciated
Are you looking for rod ends that use a spherical "bushing" or do you mean just a straight rod end with a rubber bushing and inner sleeve for a through bolt, more like a single direction pivot rather than a typical heim rod end?
X 2 on the Johnny Joints. In my Jeep for years. I have thought of using a TJ frame with Dana 44 and Currie stuff for a rat build. Smooth as silk
I've used this kit several times, it works great and doesn't break the bank.
The only thing I would like to see is for them to put right and left hand threaded ends on them.
http://www.ebay.com/itm/Weld-On-Tri...ash=item3cf031685a:g:dnAAAOSwWKtUrp8H&vxp=mtr
Yea, not too bad tho, just have to take out two bolts.
Besides you only set the pinion angle once on a street car.
