I'm getting ready to pull the trigger on a Full Tilt hub to hub mustang II setup for my pickup. I'd like it to sit real low. I'm gettung the setup with the bags and 2" drop spindles, does anyone have any pics of how low this will sit using this kit or comparable kits, and for my 9" rear I'm considering either parallel 4 bar or triangulated 4 bar depending on which one would allow me to use the bigger tire, seems like I should be able to get the front pretty low, maybe even go to aspindle with more drop, but will I be able to lower the rear enough to match the front without notching the frame?
