48 studebaker
Studebaker
Feb 14, 2012
61
fruita co
[;)i started this thing back in october and dont get alot of time on it as to i work to much. this is a 48 studebaker cab and i used an 80 gm frame [;)[;)
    89.8 KB
    107.9 KB
    115.6 KB
Hey Studebaker my mother found this in the woods near her home in Ala. If your truck turns out good, and it should, i might have to pull this one home.
    220.8 KB
    169.6 KB
i chopped off 2 feet of frame in the front and put a manual rack in for steering, the only thing is i dont know how to connect the tie rods together cuase there different sizes and the same right handed thread
    90.2 KB
    81.2 KB
i chopped the floor out and the firewall, it wasnt gonna work right
    68 KB
    85.8 KB
    90.5 KB
    74.8 KB
    96.1 KB
Omd that is a cool looking beater, id say get it. The cab is the only thing that i got so thats what i had to use, and it is my first major build
there was no side skirt in front of the door, so i had to make one, there was a little piece of hood that came with it so i welded it to the cam to extend it out a bit
    92.9 KB
    87 KB
    74.1 KB
    78.8 KB
i decided the frame was to long so i chopped out 12 inches in the front of were the cab mounts, i set up the motor 14" back from stock and lowered it in the frame
well ive hit a wall with my pics,they dont wanna load so ill have to take some new pics in the right format and post a bit later.
Connecting the rod ends together isnt that hard. The way I did mine was to measure the distance you need, allowing a couple of inches to thread up on the rod end and ball joint. Have a machine shop bore and thread a sleeve to your measurements that will screw onto the rack rod end and tread the other end to receive you ball joint. Heres a couple of pics picture that might help you understand what I am saying. After I got mine together I welded the sleeve to the rack rod and the adjustments are made from the ball joint.
Hope this helps.
Good luck:)
    47.7 KB
    47.2 KB
Build is cool....like the big block..
a few bumps in the road are normal....if you don't have an idea..somebody here will....No worries..:D
Here I potsed your doors for you
Talk about shaving doors. Pics don't do them justice, but they are real cool look'n cleaned up.
    143 KB
    140 KB
    138.1 KB
    138 KB
    132 KB
