Mr.Gussett
Yep... he can do it!
4x4
I had a friend several yrs ago ask me to build a Camaro 4x4.I told him "no way man, I hate cars on truck frames"
But that is not what he had in mind.
I ended up tying the frame together and making coil spring pockets front and rear.Then I welded up the brackets on the 1/2 ton chevy pick up axles and mounted them under the Camaro with a 4-link suspension.T-case fit up close to the floor where the Camaro's cat. use to reside and it almost looked factory.He mounted some 35" M/T baja tires on wide rims and it had a good stance to it.I made a rear bumper that had the same curve as the rear of the car. The whole car looked pretty good with not seeing a "truck frame"up under it.
I will see if I have any pics and post them.
Still don't like the idea though.
