I'm back. Sorry for the delay but sometimes life gets in the way.
I am going to start with the dash. Here is a picture of what I started with.
And
Starting with the first picture on the left corner is a toggle switch the PO had hooked up to a flasher and those tractor lights on the side of the body. Crude but it did work. it gives me great pleasure to say that it and the lights are now gone. More on the lights themselves later.
Remember that the only thing the steering column does is steering and the locking column. I cleaned everything and I mean everything off the dash and started over. Since I wanted a clean steering column I needed a way to hookup turn signals. I found it with an electronic turn signal unit from speedway motors. I bought the delux kit for single lights front and rear. It mounts behind the dash just right of the dash insert. I used industrial velcrow not to be confused with regular velcrow. I can just pull it off [difficult] and then have access to it for any work. I will try and get a picture of it. This unit is activated by a 3 position center neutral toggle switch in the left side of the dash. There are indicator lights on either side of it. The unit is pretty cool in that it turns off the turn signal by time.
[/IMG]
I just wanted to mention the headlight switch at the extreme left of the dash. Not your normal 3 position switch [off,low,high]. it is a 4 position switch with the addition of hi beams as the last pull out and the indicator light to the right of the switch. Eventually the other hole will get filled and yes no more dimmer switch on the floor simplifying the wiring even more.
This just leaves the blue knob button on the right and that is for the 4-ways. This is just momentary switch. Push once it is on and push again it is off. The amazing part of all this is it really works just as advertised.
I needed to help my mind along so I first painted half the dash:
and then I painted the rest of it.
Remember the second picture and I will talk about it in the next post.
