bob w
Looks real good, DR. Ya can't have much more fun than cutting and welding new steel.
You are on a tear man! I seem to just stand around looking at mine while scratching my nuts[S
Winter hit today. We are buried under snow.No heat in my garage... no insulation for that matter. Time to cowboy up I guess.
Your cross member is looking great.
gold03
Nice work. I want to try out that suspension one day. It is so adjustable. Did you make it or buy a kit?
Gold03
What are you using for rear tires?
How are the springs going to be attached to the axle?
Drilled the holes and final fitted the transmission cross member tonight.
Everything looks like it should work. trans is tipped down 3 degrees with the frame at ride height. I'll probably set the rear end to match, 3 degrees up.
Also started a bit of mock up on the front suspension, however I didnt have enough clamps to put the weight of the trans on the frame as well, so hopefully I can do that tomorrow after I finish welding the xmember brackets, and tack them to the frame.
Anyhow, getting closer, at least in my mind, to a roller....
