C1ph3r,
Basically, you would have to completely disassemble the spring packs and
reverse the order in which the spring leafs are arranged.
For example, let's say you have a spring with
three leafs-The
main leaf is the longest one and has the spring eyes rolled into the ends. The
middle leaf is medium in length and sits in the middle of the pack, then the shortest leaf falls under that.
On a conventionally designed leaf spring suspension, you will notice that the
main leaf attaches to the frame mounts and shackles.
Beneath this, the other secondary leafs are arranged in order of length, going from longest to shortest the
farther away they are from the main leaf. The reason for this is simple-as more weight is added to the spring pack, the main leaf flexes or bends (this is all a spring does to function-bend and spring back-hence the name "spring"). As the main spring bends, it's arch flattens out and then it comes into contact with the second leaf in the pack. the second leaf adds another thickness of spring material, thus increasing resistance to bending or flexing.
This is how "spring rate" works on a multi leaf spring. Each consecutively shorter leaf adds it's own extra resistance to bend, or flex, or spring compression, if you prefer, thereby
increasing spring rate as more weight (or load) is added to the vehicle.
It might be good for you to take a peek at the springs already on your truck-this is how they will be arranged, long-to-short from the frame side of the spring pack, out to where the axle mounts.
Now, for the "reversed" spring for the "underslung" chassis application. When the chassis is hanging
underneath of the spring packs, the vehicle's weight will stretch the main leaf into a greater arch, as opposed to the conventional arrangement
flattening the main leaf into a shallower arch. If you were to leave the springs stock, there would be
no increase in spring rate, because the increased spring arch on the main spring
would actually pull the main leaf away from the second, third, etc leafs.
So, you would take the leaf spring pack, clamp it in a vice (
very important!) and undo the center bolt and straps which hold all the leafs together. Now, the leafs would be arranged in
opposite order, with each shorter leaf placed against the main leaf
inside the curve of the spring's arch, rather than on the outside of the arch, like they are stock. So, first the main leaf, then the second leaf placed inside the main leaf's arch, then the third leaf placed inside the arch. Bolt and strap it all together and you're all done.
I
really wish I knew how to run my wife's scanner-a quick sketch would have been
SO much easier for me to explain this visually to you.
Hope this helps you to understand...I'll see if I can't get this scanner figured out a little later so I can post a pic for you.
Regards,
Shea
