52 chevy 3100 tail dragger!!
well stage 2
attachment.php
attachment.php
    81.6 KB
    73.6 KB
thank you!!! i found a coupla potential project trucks that im tryin to research the title on an had no clue where to find it THANK YOU!!!!
well got the motor out ready to start the front suspension trans plant,, but its on the back burner for now, got to do the customers 52 first , and thats goin slow trying to work around this flu bug!!
attachment.php
    68.2 KB
out with the old in with the new,, now it off the back burner and burning the midnight oil! now that the customer trucks finish, got to whoop this one out!
attachment.php
attachment.php
    83 KB
    80.7 KB
now just get the power rack and pinion on, set the motor and trans up, finish up the rearend set up, seats wiring and plumb, build the brakes, gas tank, fix the small issue in the floor pans, Get some really good priced tires and it will be rolling and stroll..EH maybe by the end of the week
rack and pinion in, pic took before i finished so dont get on me about it not in there straight. had to shim it up, because the mounts where different, on the rack, as i found out, but nothing a little shimming couldnt fix,, now mocking up the motor!!
attachment.php
attachment.php
    94.7 KB
    88.7 KB
well motor and trans is offical mounted, now to the master cylinder and hydralic clutch then plumbing
and just as a side note a 56 job i took in
well the 56 is gone and the progress on the 52, nothing,, i took the day off to ride around and see if i could get another job in the shop!!!
well didnt take no pics but got the rear done for the ride height and started the brake rebuild,, today on the rear finish it and the front tomorrow but i picked up a freebie today, and i did get a pic of it, what yall think?
attachment.php
    65.7 KB
