53 Ford doghouse year interchange.
21willys
Mar 8, 2011
2,751
Ive tried a few google searches with zero luck. I have a pertty clean 53 ford cab without a doghouse. What years will bolt on this beast? If I can get a doghouse reasonable this might be my next build. Thanks
Here where I live a doghouse is the engine cover on a cab over. If you are referring to the front sheetmetal (we call that the front clip, same as the junkyards do) then I'd think 53 to 56 should fit.
That's the info I wanted. Thanks
I think of the clip as being the front frame section.
