fuzz
Got the Studebaker on the road and first thing I had to do was adjust the detent cable. Read all the tricks and tips so making a few adjustments the trans seems to shift good [firm] except going into 4th. I understand a stock 700r4 don't shift firm into 4th, mine is stock. But it won't shift to 4th until my speed is close to 60 or more. If I run up to 50 and let off the gas it will shift to 4th.. Or put in neutral then back into gear it will shift. Also when I first backed out of the garage it acted like the brakes were on but when I put it in neutral it rolled back easy. Seems like the trans is trying to go into reverse and a forward gear at the same time. Make things more confusing, it doesn't do it every time I back up. Any ideas?
