CCROCHET
1950 ford wiring question...
Ok guys im almost read to turn over the engine and check all my wiring in my 1950 ford f1 with a 351 w. My question is how is the battery hooked up....mainly the power. I have the ground hooked up the the block as ut should be but my question is where does the power bolt to? does it bolt to the solenoid inbetween the battery and the starter?
If you need pics i can get them....
thanks,
thanks,
