Todd
He's just one of them Rusty-Chainers!
Another question, if you don't mind. Did you fab the louvered side panels, or are they ready-made off of something else?
Those were from a 31 Model A hood that was laying around the shop.
Hey Todd, did you use a TAV with the forward motion? If so, which one?
I have a couple of old Snapper riding mowers - would the drive system off of that work, or would that add too much weight? (I'm talking about the type that has a flat disk against which a drive wheel rests, and can be moved toward the outside of the spinning disk to increase the speed, and across to the opposite side for reverse.)
I was afraid of that - hoping that it was off of some appliance or something easier (& cheaper) to come up with. I have a lead on the sheet metal & gasoline tank from a Farmall C, and just thinking through how to complete the necessary sheet metal.
Not sure that would work the best.
Some of the tractor pullers used a polished aluminum side panel to fill that area. Was a nice clean look.
OK. I think I understand now. You sort of ignore the variable ration at the CVT, or you might say assume it is running full out (at 1:1) to arrive at the final ratio of 6:1 with the gears you mention. Is this correct? So then the low end ratio (at just above idle, or where you begin to get forward motion) is around 18:1. Or am I still messed up? (Here's how I'm figuring this. I've read that the CVT's low range is around 3:1. So 3 X 6 = 18.)Your final drive ratio would come from the ratio of the last two pulleys going to the shaft driving the wheels. 10 tooth on one and 60 on the other will give you about 6/1. The cool thing about the torque converters is that expanding belt pulley that changes diameter as the motor speeds up changing the whole deal from there on out. It allows you some breaking control with engine speed. We're having a ball with my kart and the grownups are in just as much as the kids. According to calculators, mine will do 31 mph. I firmly believe that....it's hauling buggy tho for kids going thru the woods out here...
All I can say is try one. Simple to build. Respectable fun for peanuts too. Go to the kart sites and follow directions if ya get stumped...nothing to it!
Lots of info here: http://www.bmikarts.com/Racing-Karts-and-Parts_c_778.html
The reason I'm trying to get a handle on this, is because I'm thinking of using a differential with a variable speed mechanism out of a Snapper riding mower as a jack shaft. From my figures, the stock ratio is about 37.8:1 in high gear. But I can easily drop that to 3.3:1 by leaving out part of the mechanism. That's about where the normal cycle cart's CVT is in the low range, so then my final gears (each wheel separate, from the jack shaft to the wheels) would need to be sort of reversed, like maybe 1:1.8, to get a final ratio of 6:1. (You can probably tell I'm still having trouble wrapping my head around this. Please don't laugh just yet.)
