What shocks are you running on a straight axle with a transverse spring? Or I should ask how much ext and compression. I wouldn't think you'd need much and since I'll be making the brackets what would be a good choice that would be easy to get at your local auto parts store? On the positive caster, is 7 degrees good? I figured 1/8 inch toe in also. Another thing I was wondering, I've decided on cross steer, since I haven't mocked anything up yet I was wondering about a steering box, and the best way to run the drag link and steering rod. The vega box would have the pitman arm pointed rearward, correct? Just trying to get a plan together and have some parts together to get a start here pretty soon. This car had a 117 WB and I figured I'd go with 120 to gain some room. Also figured spring over axle but that could change. Any suggestions or help would be appreciated, this is a 1st for me.
