So I am working on putting together an air ride suspension setup for my 42' ford truck rod that I am working on. I am wondering if anyone truly "lays frame" or with air ride will actually allow the system to fully lie on the frame when its deflated.
My worry is that if something happens to one of the front bags (i.e. it leaks, blows out, etc) that the front will drop and the frame could dig into the ground causing a terrible accident. Is this really an issue? Should I put in some sort of limit stop where the system can only drop it to an inch or so above the ground?
I have a frame design that is more or less just rectangular tubing laid on top of each other in a z fashion. So if the frame were to drop, the tubing under the cab could grab into the ground if dropped at speed.
