I put the Transmission cooler in front of the radiator and connected it with braided hose.
By
tw7256 at 2012-01-21
Since I decided to run a oil cooler for the engine I had to come up with a way to hook it up. The oil filter mount bolts to the side of the block. I came up with a 1" aluminum spacer to re-direct the oil coming out of the filter back to the engine so that it will go thru the cooler first.
By
I band sawed a 1" piece of aluminum using the gasket as a template. Then I back drilled thru the filter mount using a drill bushing.
By
I drilled a hole coming thru the spacer from the oil pump. I then drilled 1/2 way thru in 2 areas that shared the same port on the filter mount. One on either side. This will direct oil from the filter out the front edge, thru the cooler and back into the block.
By
I tapped it with a 3/8 pipe tap so I could put 2 pipe thread to AN8 fittings.
By
After de-burring and polishing it I installed the fittings.
By
Here it is test installed. All I need now in a couple feet of AN8 hose.
By
I made this gauge cluster but all I have for now is the water temp. gauge. It was left over from another project.
By
I put a CS-130 alternator on it after changing it from serpentine to V-belt.
By
Later Folks!
