skull
''SARCASM: just one of his many talents.''
start
looks like a good start[cl
tell us what ya have planned.
Later
Later
Later![]()
do the floors first, that way if ya channel it the chop may be only 3'' so you fit in the cab. the trans tunnel may have to be modified a bunch to get the right fit for the tranny bell housing and still get your foot clearance for the pedals.
look on craigslist for a running chevy cheap with a tittle, take what ya need then send the bones to scrapper. lots of people will take it off your hands. l have done this several time for motors, trannys, wiring and other parts.
suicide doors are always cool
Later![]()
Man, what a good looking truck to start with! The bed looks especially solid which is rare since back then trucks were used as trucks. You're very wise to lay out a couple extra bucks for a solid, first project. It will save you a lot of headaches. Don't be afraid of fabbing/replacing those lower kick panels. New ones are easy to make. I had to do both sides of my '40. Congrats and keep the updates coming! [cl
I used 18 gauge steel for everything I did on my cab except the trans tunnel, that is 16 gauge. If you have access to a box and pan brake, making the patch panel really isn't bad. Fabbing the actual panel only takes about 15 minutes and welding it in doesn't take too long either. Just remember to weld it in slowly or it'll warp on ya! Here is how I did mine, maybe it can help ya. Enjoy your build man, it's a blast! Good luck!
http://www.ratrodsrule.com/forum/showthread.php?t=17439&page=2
offer him a grand
the tranny should be a 7OOR4. get the lock up kit that runs the trans and eliminates the computer. any good tranny shop should be able to help. new filter and a stage 2 shift kit and ya will be happy.
the other advantange is the motor and tranny is a matched set, so you know all the parts work togother. another advantange is ya can drive the car to check out the condition of the running gear.
keep your drive shaft so you can have it cut to fit. several shops offer this service. around here its about a hundred to a hundred fifty to do this. new u-joints are good insurance at this point.
being a full framed car , if you have the skill, the frame may be able to cut down and modified to be used under the truck.
also the roof, door, hood, deck lid , quarter panels and even the floor pan are a great source for usuable metal. l have used so many of this kind of stuff in my builds over the years l lost count.
the guage panel in my 33 dodge is part of a 1966 EL CAMINO roof.
the floor pans and trunk pan in my 1966 chevelle is a floor pan cut to fit outta a 1978 caprice.
the plastic wire looms, switches, brackets and odds & ends are a good thing to hang onto, they come in handy.
Later![]()
Excellent find Sevo! Anything around the Coast here wouldn't be nearly as solid or rust free. Keep the pics coming please. perley
hell yea bro thats a good strart and a wayyy good price on that truck! keep up the good work. [P[P[P
also did you have any pics on the front z?
i have done them both ways, they are both about the same to me. the point of the "zig zag" is to help aid in lining the roof back up once it is sectioned. depending on how much you want to chop it and the style of chop you might not have to section the center of the roof
That makes sense, thank you for the explimnation.
I was wanting to do 4.5 inch chop in back with 5 inch up front. Does this give a nice raked look or should I just do 5 inch all the way around?
It depends on how much rake you're after. In my opinion, you don't perceive the 1/2" difference as a much of a "rake". It will look slightly raked but not really too dramatic. My GMC only has a 1/4" difference and below is a picture of my other cab. It is a '40 Chevy and it is chopped 5" in the back and 5 1/2" in the front. I wasn't going for a rake, that's just what it took to line the roof.
