so today i worked on my buddies RPU some. he wanted to add a 32 cowl vent to his cowl top. so i went to work on it
trimmed out the vent from brookeville
made a card board pattern of the shape of the panel, and a negative cut out of the vent to make sure i get it where i want it
scribed the cut line
all tig welded up
after some filing, hammering and dollying. and a trip through the planisher it is getting pretty close
and installed on the car
then moved on to putting on extended cab corners
stock corners
stockers removed
old rear pan taken out and extended rear pan installed
new sides clamped on
cut the old rear panel off from the sides, going to but weld them back on instead of flanged so they can be metal finished after welding
a little more progress on the RPU. reversed the fire wall and re shaped the bottom of it. wanted to make it look like it was made this way. not perfect but turned out pretty good
here is where i flipped the fire wall, making patches and patterns to smooth out the bottom of it
all patched and smoothed out
here is the back side with a new flange to make mounting the floor easier and a more factory look
and clamped in the car. just need to spot weld to the sides, weld along the bottom, and drill holes for mounting screws at the top
only got to spend a couple hours on cool hot rod stuff today
started off by making a new floor pan for under the seat bottom. 18 gauge steel, pre stretched the areas the bead rolling would be done to keep it flat.
then made a cover panel for over the tail shaft of the trans. made from on piece ,no welding was done. still pretty rough, needs a lot of finish work but ran out of time for the day on this one
a little progress on the RPU tonight. started making the floor pans and trans tunnel
floor pans cleco'ed in place
want to make the trans tunnel as small as possible since room is tight in this one. so i made some blisters in the tunnel for clearance. also had to make a blister to fit around where shifter comes out. so here are the basic steps i took to make the big weld on blister
blister laid out, the black line is the hightlight or edge line of the blister
using thumb nail shrinking dies in the recip. hammer. i shrink up to the black line
all the shrinking done
after a trip through the planisher
and all welded on. you can see all the other blisters formed in the tunnel, stills needs to be hammered and dollied and metal finished out, but that will wait until i get all the other panels made and fit up
