Today was redo day.....
I got underneath to measure my tie rod to see what size U bolts I need for the steering shock, and spotted something I didn't want to see----the wishbone was touching the transmission pan.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Apparently my rubber mount had settled a bit and let it drop. Got it up on the ramps, loosened the mount bolt, tried to jack the trans up, no go, it was against the tunnel. The AOD is a bit larger than the Turbo 350 that was in it, and had only 1/4" clearance. Why I didn't spot this before, I don't know.
So, I drag out the zizz wheel and cut the top off the tunnel. I had already covered the floor with peel and seal, so it was a mess to cut. Seen where it was hitting, no problem now. Jacked up the trans and put in a 1/4" spacer as well as a couple of pieces of thick webbing for more padding. Bolted all that back together, now there is 1/2" gap between the pan and wishbone, hopefully enough. Then an old gas stove donated it's bottom drawer for a new piece for the trans tunnel. Bolted that down with some self drillers in case I need to take it back off again. Drug the ratty carpet back over it, out of sight, out of mind!
U bolts should be in this week, then I can build the brackets for the shock. Should help stabilize the steering a bit.
No pics, didn't even thing about it until now....
