Big plans for the weekend, but it wasn't to be so....
I had plans on having working brakes on the car by Sat afternoon. My front wheel cylinders finally got here on Friday, took 5 days for FedEx to get them here from California. I got in pretty early Friday, weather was nice, so I jumped on the job at hand. Got the front end blocked up on jack stands and pulled both front hubs. New wheel cylinders fit perfectly in spite of not being listed for a Lincoln, they were listed for several vehicles from the 40's up to the 80's, just not a Lincoln. Anyway, with two adapter fittings from Speedway Motors for the AN3 brake line, all the lines were now complete. I did however go back and re bend the short lines coming out of the master cylinder after it was pointed out to me they were above the fluid level and would be hard to bleed.
I'm still not happy with the bends, may go back and work with them some more. Anyway, I could see where the grease seal had been leaking, so I made a trip to the local hometown parts house to see about getting a pair. The original ford grease seals were still on the car, but had no part numbers. We were able to find a CR seal that was supposed to fit, but they only had one, so we ordered it anyway. It came in Saturday morning, and was correct, so my man got on his computer and tracked down another one from a different supplier. It won't be here until Tuesday, so that ended my ideas of having brakes by Sat evening.
Since I couldn't work on the brakes, I decided to clean up the engine bay a bit. I cut the old E brake cable off, cut loose a old broken choke cable, and pulled out a bunch of brittle wiring. Then the rain started back....
I am under the carport, but the car is facing out to the front, and the rain was blowing in right where I need to work. Plus it started getting colder, so I had some stuff that needed doing in the house, honey do stuff, so I went on in and did my penance. Maybe I can get back on it next weekend, but they're calling for rain then, too.
