Neverdone
Never, how about spindle to spindle......just curious how you
tied it all together after narrowing the cross member?
sectioning the center link?
Thanks...
CORRECT!!!
Still running the stock pitman and idler from the truck. Measured center to center on the idler and pitman at the exit of the gear box and the base of the idler. Cut a section from the center link so the holes on the center link will match the measurements. Ground down the link at the cuts to put a healthy bevel on it. Cut a sleeve to fit tight on the center link. In the center of the sleeve drilled a hole all the way through. Put everything together with the holes in the sleeve at the seam on the link. Through the hole tacked the two pieces together. Slid the sleeve all the way to one end, and welded the seam solid. Slid the sleeve back to center and welded each end of it as well as plugged it in the holes that were used earlier.
I will try and get ya a pic of it. Hopefully my description makes sense to ya.
