Okay, you guys aren't allowed to poke fun at the sad state of my garage.......seriously :/ I'm almost embarrassed to show it.
Went to the scrap yard today, found an axle out of a 400 Honda 3 wheeler. Drum brake, and surprisingly, the exact same sprocket as the 350
AND the sprocket location, relative to left and right on the axle, matches the location on the bike!!!
SO, now I have a rear end. Bought some wheel adapters to change the 4 on 130 bolt pattern of the rear to the more standard 4 on 4 used on golf carts.
This way I can buy DOT street tires and be a little more legal in that aspect.
Looking at using 10" wheels 8" wide and about 19" tall. There will be enough sidewall to keep the hard tail ride at least a little softened.
I'm going to drop the frame to about 4" from the ground.
I pushed up the front forks to see what it looks like. Not bad. If I could get them shortened 4" easily, I would run with it. Rather I think I'll add a little rake. As long as the trail is reasonable, a chopped neck it will get. Trikes aren't quite as temperamental to weird trail angles as 2 wheelers are.
Still trying to figure out what carbs these are do I can rebuild them.
Here's some photos.
Just guessing on the total wheel/tire height of ~20", centerline of the axle shoud be right around the 10" mark. These are more realistic.
