Sure Sam, Lets talk about what it takes to bend 1.75X .25 wall HREW tubing. Which is what all the straight tube in this frame is. Then after that lets talk about a double "ladder" type frame made with the same tube.
HREW Tensile Stength = 40,000 psi
Diameter (in) Thickness (in) ID (in) Cross Sect. Area (in^2) Tensile Strength (lbs) Weight (lb/ft)
1.75 0.120 1.51 0.61 24,579 2.089 lb
I couldn't find the numbers for .25 wall.
We should probably compare it to 2x4 rectangular tube.
