Flipper_1938
He recycles the right way
94-95 camaros had a 3.4 liter version of this motor. That motor with the 82 ignition and an aftermarket intake would be fun.
If a Mustang II front suspension will hold up under a BBC, I think you are likely OK with a baby V6 sitting on the Opel suspension. If you find one with a 4- or 5-speed, it ought to fit in your tunnel OK, too. Guessing here. Its been a few decades since I played with Opels.I'll probably end up with that motor then. I'll have to look at work and see if they have anything. Do you guys think the opel axle will hold up?
I have a 5 speed that came out of a blazer. It's a T-50. Looks a bit big though. Does anyone know if the t50 is a sibling to the t5 or what the differences are between the two?
You can make any diff a limited slip for a price. I think you are over thinking your project. Does it really need a limited slip diff if you are not taking it racing. Other than the cool factor of saying it has one, I am thinking it is unnecessary for this application. Early in my build, I was looking at putting a Ford 9 in my 39 ford PU. The lads at Dutchman told me to save it for a bigger badder project. The S10 diff will handle 400 HP. Point is, this project looks like a fun zip-around car, rather than a monster race car.I actually have a 4 lug mustang rear in the barn. I need to see if the width is the same. Do you know if there is a way to make it posi or limited slip?
I'll have to look at the numbers on that trans when I get home.
Yup. That pretty much covers the spool story.I've driven a car with a spool before and it really is just for one thing - straight line drag racing. Very weird driving around corners when the car is trying to go straight, also a little embarrassing in parking lots or just turning a corner at a stop light when the inside tire is squealing constantly...
BTW, those older GM 2.8 V6's are a piece of poo IMHO
