twistedz
Active member
Nice find man. Around here a grand would be a steal.
should run your air ride controls like this. Lot cheaper and looks badass
Thank you!Dude, that's a beautiful cab you got there.
Like the others have said, money spent on good metal to start with is money well spent.
The little truck in my avitar is a great example... I paid $800 for it off a used car lot 6 years ago and promptly removed and scrapped almost everything that bolts on, then bought better replacements. The money I have in that little s**tbox (that hasn't moved in 6 years) I could have bought a solid southern truck and been driving it long ago. Penny wise, pound foolish.
Like that you're not going to chop yours. I agree, the proportions are right on.
Looking forward to seeing how this turns out.
Regards,
Shea
is it really a 38-39? it looks like it at the fire wall but has later doors on it. so the body lines wont match. could be an optical illusion with the paint, they just look like 40-46 doors
It's not the look for everybody, but I went with a 56 F100 front axle,I see them cheap on craigslist sometimes where someone is going MII frontend..
I have less that $200 in my entire front axle/suspension including disc brakes..I know a lot would rather have a more traditional hot rod looking front end and I probably would too..but this fit the budget..pics are in my build thread in my siggy if you want to check it out..
Your front end setup isn't bad. I'm not dead set on having a 100% correct tradition rod, I'm not planning white walls, nor a lot of the traditional stuff anyways, so it may be a good option for me I'll look into it for sure!
Mine is a CITY rat it's not traditional by no means, but you know what it turns heads. click on my build thread down below there go look
You guys are giving great feed back and it's really helping me move my idea toward a plan. I'm really thinking air rear and the standard spring front now, I'll have to decide on whether or not to cut the body up or not... Anyone have any ideas how I can strip some of the paint off and leave the patina??
Strip the paint where it is, you shouldn't have to strip where the "patina" is...
Why not go with traditional suspension front and rear? Smaller kickup necessary out back, less space needed for air tank, compressor and switches.
I know it's a small cab, but it's not a mini truck.
They didn't have air suspension on hot rods back in the forties when people started building bobber style trucks. Nothing "traditional" about it.
No criticism intended, just giving you a different viewpoint. If you go with traditional style suspension, it would likely be a little more cost effective and easier to build, too.
Regards,
Shea
