sgo70
I'm getting ready to run my brake lines and it's my first time ever doing this so I want to make sure I get it right. I have 49-54 chevy calipers from Speedway and an '86 Ford 9" rear drum. Here's what I have so far:
Front:
Master cylinder-2psi RPV-T connection-through frame fitting- flex line-caliper.
Rear:
Master Cylinder-pressure brake switch-10psi RPV-APV-flex line-T connection-wheel cylinders.
Hopefully this is right so far.
1. Are you supposed to use teflon tape or copper washers on the connections??
2. Banjo fittings on the calipers??
3. If I use steel lines what brake fluid?? Will they last??
4. 3/16" or 1/4" lines??
Thanks, I'm sure I'll have more questions,
Sean
Front:
Rear:
Sean
