35Mastr
Mastr Blastr
I have to plumb the booster to the proportioning valve.Has anyone used braided line instead of hard line for this?I have seen it on a couple of cars but I have never done it.
Feed back please.
Feed back please.
Its just that I ruin more line then I end up using due to bad flaring or just wrong bends.
Its in a spot where it is going to be seen so it has to be done right.I just tried to do another one a little while ago.Kinked it right at the last bend.Another one for scrap.This is becoming all way to frustrating.
George, where is your proportioning Valve? Some of the companies such as Master Power Brakes make prebent lines for the factory type proportioning valves that are mounted near the master cylinder.
I am bending them with a tubing bender.if you have the thread fro the HAMB.I would love to see it.This is becoming a nightmare.Sorry man, I know what you mean. I too have a pile of wasted lines I have kept for some reason. I may buy the double flareing tool someday and use some of them.
How are you bending them?
Do you have a tubing bender? If you dont, pull real hard on the ends when you bend it over a pipe or something round and this will help from kinking it.
I think I also did a search on the HAMB for brake lines and got some good tips.
Could you move the proporsioning valve a little? OK, bad idea, just trying to help.
Actually muy cousin has a shop there.It probably was ther when you were.Hey, I just noticed your in Newark. I had a shop on W. Winton in Hayward for years before moving to S Cal. We were neighbors, wish I could come over and help you.
I am probably going to order my stainless steel lines this week from Inline Tube. They will put the ends on for you and for about and extra $ 5 per tube you get stainless end fittings too. I am going to run braided for a short distance from the master cylinder to the residual valves, then hard line the rest of the way, until I get to the wheel brake lines. The reason I am using braided from the master cylinder is because of the tightness in that area between the M/C and the tranny.
I never have had luck double flaring brake lines, so I let the experts do it for me.
Guy I know could build the Eiffel Tower or detail the Taj Mahal ... but couldn't bend tubing if you put a gun to his head. He used to use clear, plastic , tubing from the local hardware store and spray foam insulation ... cut to length , he'd spray the foam in , bend to desired shape , hold a few seconds 'til she set up ... then take it and have his lines made up.
( Used the same method for custom , "tricky" exhaust bends too , using radiator hose. )
