Brake Question!
bradyjames
Active member
Jul 6, 2011
42
Sacramento, CA
I have a drum/drum brakes and just a got a new power master cylinder. Do I need to use a proportioning valve with that?
Thanks!:confused:
    101.5 KB
A porportioning valve is used to even out front to rear braking under hard or panic stops. Adjust your brakes with a slight drag ,then go out and on wet pavement , do a panic stop to see if the front or rear lockup first. Adjusting the brakes will even out a slight difference but a porportioning valve will compensate for a big difference. Use an adjustable one ONLY, do not use any factory one as they are matched to a particular vehicle for weight. I have used different wheel cylinders and shoe material to even out the braking bias as well.[;)
