Yankee Transplant
He started out with nothing, he still has most of
about tired of the brake issue ,, both feet on pedal and it will slow you down to a stop ,,, cant drive it like this ... done scuffed up the shoes and drums and adjusted to a scrub no help. replaced the lines from 5/16 all the way threw to 1/4 till it gets to the rubber then its 5/16 to the cylinders. still the same , got new manual master for a 76 c-10 no difference. I have a 79 camaro rear under it , but it acted the same way with the 64 pick up rear under it . Doc helped me last year (I think) with ID on my axle , can you help again Doc ? I will put it on the wall this time ,, I think he said it was a 55 ... Im going to do some shopping for a disk brake conversion and see if it will fix everything . I have to many mis-match parts on here to make it work i guess . I drove drum brakes for years so I know what they shound be .
