If you are talking about the front axle and all, then id say no way. The pumpkin on the front is offset and wont line up with any trans for the rear. For it to work it would take some pretty major fab work. Now if it was centered then yeah it would be like a normal rear, but its not it sits off to the side.
If you are talking about C bushings and coils with a trac bar, sure, that would work. The hard part would be moving the metal mounts over to a standard axle.
well i did it. The wedges were made from cast, but they were welded onto the axle. I drilled the I-beams too. This setup is wicked. Absoutly no wheel hop or axle wrap what so ever. And the best news is i found out that I HAVE A POSI 9"! Before when i just had it in the air i thought it was an open diff. Glad i was wrong.
true Posi, or just limited slip? Im going to guess just a factory limited slip. If it was a true 100% Posi, then you'd skip around curves, that wouldnt be very fun to drive.
A Posi is a limited slip. The term "posi" is short for Posi-Traction, the trade name for General Motors limited slip diffs in the early days. Just like Sure-Grip is for Mopars. The only true "locker" was Ford's Detroit Locker.
