we usually channel them till the rockers are even with the bottom of the frame,if you want the rockers on the ground when aired out.I have a frame table at the shop that we use for this,but iv seen it done with 2x4 square tubing ontop of jackstands under the chassis...then channel the body till the rockers hit the 2x4 then you know when the body is even with the chassis.
