maddog
Here he comes to save the day!
I had to go out and check to make sure mine was still in the shop. Looks like a clone for sure. If the bearing hole is a little big a wrap of electrical tape on the plasma head will fix that. also, you may have to slot the roller bolt so you can adjust the head a little closer to the work. Good job, the tool should work well for you.
You may not have knoticed, your iron worker and 2 welders are gone.
