klink
Klink, without working up a sweat, definitely able to mark the axle with a 1.5lb and a small nail punch
If you can leave a mark with a punch then the axle is softer than the punch (which isn't very hard). Early Ford axles were forged which makes them strong by compressing the steel; there was no need to heat treat them. If it was my axle I'd cut off the brackets and clean up the perch bosses and use it. I can't tell how the perch bosses were capped from the pictures in the other post. If you're lucky they simply welded "caps" over the holes. For piece of mind you can have it tested for cracks which wouldn't cost much.
