Hello all,I am going down to look over my possible project. I have two 1950 international pick-ups one is 1/2 ton and 1 is a 3/4 ton. The power train will be coming from a 1966 meteor with a 390 engine. As I am a newbie is there any suggestions on which frame I should use for my build? The internationals could invert the axles to lower the ride height or should I use the 66 and cut the springs? I do not need to slam it down, it is my first rat rod and want to keep it kinda simple for the build. All suggestions welcome ... Thank you.
