- Joined
- Nov 5, 2015
- Messages
- 3,254
I will add my thank you for this tip also, Mr. dutch. My brain is spinning with the possibilities. Pounding in lines, curves, spirals, and so on, to get where you want to go. This is great! I have never thought about it in this much of an organized way. What spacing do you use for the lines?
Skip, most important is you understand the basics of what shaping metal is.
You can do just 4 things with sheetmetal
- cut
- bend
- stretch
- shrink
these 4 enable you make any shape you need/want. So all fancy tools like e-wheel ,powerhammers, shrinker/stretcher are there to make life easier, but only when you understand what yer doing.
At the end of the day you can shape what you want with a couple of hammers and dollies.
So, for example , you have a 10" square of sheet and you want to have a convex shape, you can either shrink the egdes or stretch the center, of both. This will result in raising the center of the panel. Just try... leave a 1" frame on the edges of the panel which you don`t touch. Draw lines up & down and left to right at say, a half inch or a tad more apart. Take a autobody hammer with a light curved surface and hit the crossings on an anvil ,dead on the anvil. You flatten the sheet and therefor enlarge the surface, which results in raising the panel. check with ruler
Sorry for the interruption Torchie...
