Old Iron
Make sure the 331's don't have the extended bell housings, granted they can be milled off but, who need the machining cost.
I'll stick with ya to see these babies.
[P[P[P
Stick around indeed [ you have a lot of work to get done[cl
Well, there goes the Christmas money. One of my buddies just received a removable leg.
Good luck with the hinge.[cl
Well.......
I'm supposed to stay out of my leg for a while but since I have access to a full on machine shop tomorrow I may have work around that.
We are going to see if we can get the pin out of the PS door upper hinge.
I went the big bucks($18 plus shipping) to get a genuine 1949 Dodge Coronet hinge pin.
We shall see.......
Keep on keeping on.
Of the 6 hinges (not counting the upper two on the rear doors, which are external) on my 46 Plymouth, I was only able to press out 2 of them. The others were all twisted off just below the knurled area, & had to be drilled out.
But I would be interested to know the diameter of your pins.
I have received conflicting info for the Plymouth pins, and some say it was a common practice to ream the hinges for over-sized ones. One person told me that they have a Dodge parts book that says that the pins were originally 5/16" diameter. No one else gave any info like that, and none of the books I have give any dimensional info at all. I asked him to tell me what book it was in, or to send a scan of that page, but he never responded. But because of that one reference, and because the insides of the hinge tongues looked like they had drill bit gouges in the bores, I concluded that mine had probably been reamed out to 11/32" (.34375 in.). Now I'm thinking that the pins were actually 11/32" to start with. I wasn't surprised that mine might have been drilled out, because my car has over 91,000 miles on it, and as you know, there was no bushing of any kind in the original design, so it was steel on steel.
I believe you are right ,bob.Chinese Grade 8 is around 3. Must be a worn in step in the pin that is hanging up on the housing. Did you soak in vinegar over night to free up the rust?
That was our next step dutch. If we had a torch handy.I would torchie it
Here's what I came up with..... Neto.
Conflicting info is the norm when It comes to these cars.
My pin mic'd out at 3/8 inch.
The pin that was sent to me that was for the "49 Dodge" is way too small.
No matter as we only got the pin pushed out about 3/4 of an inch and it stuck.
No amount of effort would budge it.
So now it's off to the machine shop for real.[P [P [P
Pics tell the story. I even bent a grade 8 bolt trying to push the pin the rest of the way out.
Keep on keeping on...
