I went thru the effort to get the Dodge back on rollers today. This is the kind of stuff that is hard on me. Having to get down and up and down and up.........Well. You get the idea.
The issue is this .
As you can see from the first Pic there is something really catawampous going on here. The DS looks like it is way lower then the PS distorting the back of the body.
Well it turns out that the DS isn't low. The PS is high.
All of this is being caused by the rear axle / drive shaft /Trans, shifting from pushing the car around.
When I chopped and sectioned this I had everything squared up, braced and leveled.
You can see by the pics of the rear tires that the axle has shifted as well as pushing the trans over to the PS. The rear axle is just temp clamped with some wooden lowering blocks that I used for a mock up.
I put a jack under the DS and now all's pretty much back where it needs to be. Last teo pics.
So at this point I will need to find a pair of matching profile tires for the front (I compensated for that with blocks to get the frame level from side to side before all the cutting) Get the trans pulled and the rear axle back to where it needs to be.
Then I can get serious about finishing the welding on the body.
Hopefully I can get some help with some of this. If not...."Once more unto the breach, dear friends."[ddd
Thanks for looking in....
