05snopro440
If not, you can probably remove the vacuum canister from the intake and plug the hole with a plumbing fitting or even anything you can attach rubber hose to which you can plug with a bolt.
I'm trying to figure what this vacuum canister is for.
I’d use starting fluid myself. It will burn out quicker so no problems over revving it or not being able to shut it down. And it won’t spray back all over you if it backfires, one quick fireball and it’s gone where gas may go everywhere before it ignites.
Had a buddy go to another guys shop to get something. Whatever he was getting was blocked in by his race car. Key was in it, so he jumped in and cranked it, backed it up, got what he went for and left. When he carried it back later that day, his buddy was home. His buddy wanted to know how he moved his race car, he told him. He then carried him over to the work bench, there sat the carb! Looked under the hood, the gas line was stuck down in the intake! He said he wondered why he couldn’t get it to idle down!
The one in the intake is an EGR valve. You don't need it. Remove it any way you can and block it off.
The little one on the carb is a choke pull off. Leave it there.
No complaints here Doc. And I apologise if that post came across that way. It was a long ,hot ,day.Nothing wrong with a 200-4R. If it's in good condition, you still have a good, capable overdrive trans.
2 bolt mains or 4 bolt mains mean nothing, unless you're building a 10 000 RPM screamer...
Stories like that remind us all why we do as much of our own work as possible,Mac.Again, I agree with Dr. Crank, totally.
I have a story for you about the 'two/four bolt mains' conundrum. The Hemi I have in my '34 Plymouth was a 270 ci with two bolt mains. It came out of a gravel truck and the owners nickname was 'Cannonball', so you can guess how it was driven all day. The rebuilder/shyster did quite a bit of machining to the block and dug up some four bolt caps, all at great cost to the customer. The customer was going to put this stock gravel truck Hemi in a motorcycle. He thought the motor was tough enough, before, and wouldn't pay the bill at the shysters place. The rebuilder/shyster should have been shot and then put in jail. Sometimes you can get by with two bolt mains.
I hate changing plugs on any thing newer than about a 69
Take care and stay cooool, if possible. [P
There, I fixed it for you soltz ![ddd
My 88 Firebird you might get two plugs out the top, the rest have to come out from the bottom. No way to even see them from up top.
My youngest son had a 94 Firebird; I despised working on that thing. I wonder what GM engineering genius decided the engine should be 50% recessed underneath the dashboard?
