kelseydum
Sorry to post this on the rat rod site, but I figured since I'm a regular you might help me out.
She's dead again. I had this problem about 3 months ago since it happened last. Basically, my car won't start and me and a couple other guys can't figure out why. It's a 1999 hyundai elantra 4 cylinder. The last time this happened I went ahead and did a full tune up. I changed all the belts, checked the timing, changed the spark plugs and wires, changed the fuel filter (which I just did again today), flushed the radiator, put on new battery terminals (clamps), changed air filter, oil change. The radio and everything works fine, she's getting electricity but seems to be getting no gas. I had noticed the EVAP canister had busted and was spitting charcoal into my fuel lines so I changed that too (before the first fuel filter change). The gas was nice and clean this time I changed the filter so I don't think it's the charcoal. She was running pretty well until today when I noticed she wouldn't start right up so I took her home from work so I didn't get stranded (I work alone). Also, I haven't tried it yet but last time this happened it wouldn't even start with ether to the throttle body. It eventually just started after cranking it for a long time.
Soooooo... by process of elimination are we down to fuel pump or the injectors? Sometimes it acts like it almost cranks but won't quite make it there. Is it flooded or something? I really don't want it to be the fuel pump because it's in my gas tank.
